Modify existing view template
mrensing
mrensing
I thought I was going about this the correct way, but since I am here and posting, it isn't working out the way I thought it should.
I have a class storing the ElementId and bool value for the visiblity of imported DWG layers. That class is below
public class CategoryVis
  public ElementId Id { get; set; }
  public bool Visibility { get; set; }
The tranaction I am using to update the View Template is:
using (Transaction transaction = new Transaction(this.doc, "Transfer DWG Visibility Settings"))
  transaction.Start();
  foreach (importedDWG imp in sourceImports)
    foreach (CategoryVis categoryVis in imp.categoryVis)
      view.SetCategoryHidden(categoryVis.Id, categoryVis.Visibility);
  transaction.Commit();
 In the code above, view is the View Template.  When I run this code, nothing happens.  There is no command listed in the undo list, and the view template has not been modified. What am I missing to update this view template?
mrensing
So, a fresh look at it on Monday reveals that I was not choosing the correct View template to read from
