Modfiy, SaveAs and Rollback
BenoitE&A
BenoitE&A
Hey,
We are creating an add-that would do the following for a given set of areas:
1) modifies the document according to the given area
2) Save the modified document to a new document
3) Rollback the changes
Then switch to the next area of the set.
I have tried the following ways, all based on the idea of a TransactionGroup that I rollback at the end of step 3. But none of them work:
Idea 1 : use SaveAs.
Pb : SaveAs is not authorized in an open Transaction or TransactionGroup
Idea 2 : use a PostCommand with SaveAsLibraryGroup
Pb : the postCommand is executed once the flow is terminated so that I can not Rollback my TransactionGroup.
Any idea / suggestions ?
This item is similar to this one :
https://forums.autodesk.com/t5/revit-api-forum/modeless-rollback-a-transaction-after-commit/m-p/8127...
Benoit
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
stever66
I'm not sure exactly what you are trying to accomplish, but once you have done a "Save-as", I don't think you can go back and undo a transaction on the previous file.
Maybe try a different workflow?  Like copy the original file (or open and do a Save-As), open the copy, make your changes and save, and then just reopen the original unchanged document and repeat?
I'm also not sure offhand what you can do without a post command, so I may be way off here.
jeremytammik
Dear Benoit,
Thank you for your query.
  • Save the original document A.
  • Make modifications and save as B.
  • Open A.
  • Close B.
  • Make modifications and save as C.
  • Open A.
  • Close C.
  • Et cetera ad infinitum.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
BenoitE&A
Hi Jeremy, hi Stever,
You are both right, the best way is to change the workflow : save before, than modify.
Once answered, some questions look dumb...
The Rollback idea was cool though...
Benoit
Benoit FAVRE
stever66
Its definitely not a dumb question... I'm sure rolling back the transaction would have been a lot faster than all the open and close business if there was a way to make that work.
I did have another thought, but  since I have a pretty limited knowledge of C#, I'm not sure there is a way to make this work either.
Is there any way to make a copy of the document in C#?  I'm pretty sure something as simple as this won't work:
Document doc1 = uiDoc.Document;
Document doc2 = uiDoc.Document;
That obviously won't work because both doc1 & doc2 are just references to the same document.
But if you could do something that is the equivalent of:
Document doc2 = doc1 by value;
You might be able to start the transaction on doc2 and save it.  Then go back to doc1 and repeat.
I'm just not sure C# can really provide a real copy of a document variable without just creating 2 references to the same object.  And you might also be running into the postcommand problem again.
BenoitE&A
Hi Stever,
Thank you for the idea. Yes you can create a Document which is only a pointer to the same document (Document newDoc = uidoc.Document;). But I am not sure whether you can modify this document without saving it (writing in memory), and saving is not allowed as long as your Transactions are not closed.
I am back to my original question though. The integral copy of the document then modify it is a real pain for what I want to do (slow, long, and not reliable). So I would really like to do my previous hint :
1) modify the document
2) extract the modified geometry (the only way I found was with the PostCommand SaveAsLibraryGroup)
3) cancel the modifications
Would anybody have an idea how to do this ?
Benoit
Benoit FAVRE
