Modelless Second Form
thannaingoo.api
thannaingoo.api
Dear Developer,
I am trying to use the modelless form to be modify the model although the form was open.
I can access the model to modify when the first form was open.
I cannot access the model when the form2 is up.
Kindly help me, How should be do for form2 to be access the model?
Below code is how I load the form2,
using System;
using System.Windows.Forms;
namespace Revit.SDK.Samples.ModelessForm_IdlingEvent.CS
    public partial class ModelessForm : Form
        private Request m_request;
        public Request Request
            get
                return m_request;
            private set
                m_request = value;
        public ModelessForm()
            InitializeComponent();
            Request = new Request();
        private void EnableCommands(bool status)
            foreach (Control ctrl in this.Controls)
                ctrl.Enabled = status;
            if (!status)
                this.btnExit.Enabled = true;
        private void MakeRequest(RequestId request)
            Request.Make(request);
            DozeOff();
        private void DozeOff()
            EnableCommands(false);
        public void WakeUp()
            EnableCommands(true);
        private void btnExit_Click(object sender, EventArgs e)
            Close();
        private void btn_form2_Click(object sender, EventArgs e)
            this.Close();
            Form2 f2 = new Form2();
            f2.ShowDialog();
Thanks Advance,
Naing Oo
RPTHOMAS108
I don't know what you mean by interact with model: read/write via API while the form is showing or interact with UI?
The second form is called with ShowDialog instead of Show, so it will be modal not modeless.
