ModelessForm_ExternalEvent SDK sample
Hello everyone,
I am new to develop in Revit API and started with SDK samples.
I am just trying to implement ModelessForm_ExternalEvent sample, but it keeps throwing me an exception stating that "Object reference not set to an instance of an object", I am not sure whether the problem is my software version or something else, please can anyone advise !
Many thanks,
Aziz
BELOW IS THE CODE:
public class Class1 : IExternalApplication
public static Class1 thisApp = null;
private ExternalEventExampleDialog m_MyForm;
public Result OnShutdown(UIControlledApplication application)
if (m_MyForm != null && m_MyForm.Visible)
m_MyForm.Close();
return Result.Succeeded;
public Result OnStartup(UIControlledApplication application)
m_MyForm = null;
thisApp = this;
public void ShowForm(UIApplication uiapp)
if (m_MyForm == null || m_MyForm.IsDisposed)
ExternalEventExample handler = new ExternalEventExample();
ExternalEvent exEvent = ExternalEvent.Create(handler);
m_MyForm = new ExternalEventExampleDialog (exEvent, handler);
m_MyForm.Show();
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
public class Command : IExternalCommand
public virtual Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
try
Class1.thisApp.ShowForm(commandData.Application);
catch (Exception ex)
message = ex.Message;
return Result.Failed;
public class ExternalEventExample : IExternalEventHandler
public void Execute(UIApplication app)
TaskDialog.Show("External Event", "Click Close to close.");
public string GetName()
return "External Event Example";
jeremytammik
Dear Aziz,
Welcome to Revit API programming!
Please start with something simpler first, e.g., work through the getting started tutorials:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Alternatively, work through the hello world samples in the developer guide:
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-93BC4416-FA94-44B3-AA66-931839DA44B4
Good luck and have fun!
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi Jeremy,
Thank you for your warm welcome and advice.
Yes, I am working through the getting started tutorials and all is going well until reaching this Modeless Form SDK sample where I got stuck. However, after more trials I tried to change something and it did magically work, I created a class instance from but not assigning it a null value. I am sharing it below in case someone else is experiencing the same issue:
// class instance
Public static Application thisApp = new Application();
Cheers,
Aziz
shibuchellappan
Can you please sent me the code. i am new in revit api.
jeremytammik
Welcome to Revit programming!
Work through the getting started material:
Install the Revit SDK.
The code is included there.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
tiagofrbr
It worked for me too, thanks!
