Model Pattern vs Drafting Pattern
dgoff96
dgoff96
I am working on a tool that collects all of the patterns in a file. I am wondering how to access the parameter that tells you if the pattern is a model pattern or a drafting pattern? I have tried
patternElement.GetType()
but all that tells me is that it's a FillPatternElement. Nothing in the API docs is jumping out as an obvious answer here.
Any ideas on how to get this information?
Thanks!
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @dgoff96 ,
try using the below code
FillPatternElement FPE;
FillPattern FP = FPE.GetFillPattern();
FillPatternTarget FPT = FP.Target;
FillPatterenTarget returns the type of fill pattern.
If this helped solve your problem please mark it as a solution, so other users can get this solution as well😊
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
dgoff96
@naveen.kumar.t  that did the trick, thank you!👍
