Model checker for revit, Checking if there is duplicates in projet parameters.
Hello everybody,
first of all I apologize for my english which is not perfect.
In my internship I am looking to check with the Model checker for revit, if there are duplicates in the project parameters (and shared parameters), and also in the project elements (architectural objects). I tried with the views and it worked by checking names of the views that contain the text "Copy".
If you have any requests I am interested.
Thank you in advance
jeremytammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
