Model Checker - Check Sheet Number, conform to company standard
CptnCaveman
CptnCaveman
I'm using Model Checker and I'm trying to run a check to verify Sheet Names conform to company standards. Example: A100 or AD100 (Must start with Max. 2 letters in caps, followed by Max. 3 digits). Everything I run passes things that should fail. I've checked my Regular Expressions on RegEx101.com to confirm working. See attached Image of things I've tried to get to work. Help Please
jeremy_tammik
You could try to start with exactly two letters followed by exactly three digits, using [A-Z][A-Z][0-9][0-9][0-9].
Once that works reliably, add another, separate rule allowing just one letter, and another allowing just two digits, etc.
Less elegant, maybe, but more foolproof.
JasonKunkel
The Category of your filter should definitely be Parameter, not API Parameter. The API Parameter checks against the Properties of an element access via the API.
I rebuilt your check and ran it against a sample model. These are the filters I had:
And it ran as expected. These are my sheets:
And only one of them, sheet "12", comes back as Failed in the Model Checker report:
As noted above, be sure you are checking again Parameter and not API Parameter. And be sure this isn't an extra space after the parameter name, or in the data field for the regular expression.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
LinkedIn
CptnCaveman
I did try that expression, the primary issues were using API Parameter instead of Parameter & SHEET_NUMBER instead of Sheet Number.
Thanks again!
