Missing (zero length) long rebars
jaroslav.kopecky
jaroslav.kopecky
I have case where created long rebars are not visible, they finally have got length equals zero.
It seems it is bug, please could you check this case?
Greetings, Jaroslav.
.rvt project,
vs solution with external command implementation,
addin manifest. (rename .xml to .addin)
can we get an answer? Otherwise we will not be able to finish the interface for rebars to Revit. I think it would be a pitty if it would not be possible to link RFEM and Revit in that way.
I look forward to hearing from you as soon as possible.
Best Regards
Walter Rustler
Dlubal Software
jaroslav.kopecky
It seems to have same cause and solution like in:
rotation-of-stirrup-rebar-rotated-beam-api
passing very very precize vector is essential.
