Mirroring Elements Issues
jacsmithstrongtie
jacsmithstrongtie
Hello everyone,
I am looking for some help with a using the ElementTransformUtils.MirrorElements(doc, MirElems, MirPlane, False).
The transaction does not commit and the Exception reads
I have wrapped this in ElementTransformUtils.CanMirrorElements() and the result is true.  So, my question is why would this be happening?  Is there a way to see where the bad element(s) may be?
Any help would be greatly appreciated!
Thank you
Mohamed_Arshad
Hi @jacsmithstrongtie
       This exception rises when you try to mirror pinned elements, Place a checkpoint Before mirroring to check the element are Pinned or Not.
Exception Reference Image:
MirrorElements Method (Document, ICollection(ElementId), Plane, Boolean)
Reference Code
///Check the element is Pinned to Not
                if (e.Pinned)
                    e.Pinned = false; ///Un-Pin the element if it is pinned
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
