mirrored repeating detail items
I have an app the explodes detail components into filled regions and lines and I'm having some problems with repeating detail components (rpc). I can't tell when a rpc is mirrored. Using the Revit Lookup tool to snoop a rpc, I can see the location curve (a line element) has 2 XYZ classes that designate the origin and direction of the line the repeating components should follow. If the rpc is mirrored the value of the direction XYZ class changes but I can't understand how the changes infer the mirror direction.
TripleM-Dev.net
Use GetGeometry and include geometry not set as visible (see in Revit Lookup).
It seems to always return 5 lines (locationline and the 4 boundaries?).
the 3th and 4th are perpendicular to the locationline, and they give a different direction for a mirrored repeating element.
Determine the transform needed to get the vector vertical, apply same transform to the 3th line it's X component will be positive for drawn element and negative for mirrored ones
Other approach could be to determine the direction between 1e and 3e line (clockwise/counterclockwise), maybe easier?
- Michel
