Method to Offset/Parallel a Line/Curve
Hello
Is there a function/method that will offset a line for me?
For example; if I have the following model line, I want to create another model line exactly the same as this one just with an offset distance of 500mm away:
I've looked through the api but theres no function 'Parallel();' or 'Offset();'.
Line line = doc.Application.Create.NewLineBound(segStrt, segEnd);
Line parallelLine = line.Offset(line, 500); // not method like this
Correct me if i'm wrong, but offset and parallel are nothing more then a copy in a certain direction. So if you want to offset your line you can copy it 500mm in the Y direction.
gopinath.taget
This blog post may help:http://thebuildingcoder.typepad.com/blog/2010/05/model-curve-creator.html
Gopinath
