Merge 2 walls on the same line (Revit 2016)
Hello, guys,
is here a away to merge (not to join) 2 similar (e.g. same type, height, width etc.) walls located on the same line using Revit API?
In Revit UI it is possible to do it by dragging end point of a wall to an end point of another wall (see attached file merged_by_Revit_UI.jpg). Using Revit API it is possible to join (not to merge) these walls, however there are still 2 walls (see attached file joined_by_Revit_API.jpg).
Thank you in advance,
Aurelijus
Revitalizer
perhaps you need to call doc.Regenerate() method after adjusting the Walls.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Hey, Revitalizer,
calling method doc.Regenerate() after recreating location line of wall does not merge walls 😞
Aurelijus
have you found any solution?
