Measure Distance between Elements
Hi all,
I have been trying to get distance between two Elements in my C# plugin
Have tried to get distance between faces by iteration thru all faces (distance between origins), but could not accurate results.
In dynamo we can get this by using Geometry.DistanceTo node, is there a way to call this functionality in my plugin?
From what I researched and tried, I could not convert Revit Solid to Designscript Geometry to use in the above Function. Is there an alternative?
Pleas suggest if there is any other way to achieve this.
Thanks in advance.
snabil76
simply get the origin of each element and draw line between each 2 point then get the line length
or you can check the distance direct by XYZ.DistanceTo
hope if i covered your question
Best Regards,
Sameh Nabil
