Material Tag created by API does not show material data
boostyourbim
Message 1 of 25
boostyourbim
This code creates a wall and material tags for each layer. The tag leaders are placed correctly (in the center of each wall layer) but the tags do not show the material data.
Manually making any tweak to the tags (such as moving the leader elbow or text location) will get the tag to properly show the material value, but of course the goal of using the API to create the tags is that they will show the correct data without any manual intervention. I've tried different permutations with transactions to no avail. Any ideas?
            public void MakeWallAndTag()
            Document doc = this.ActiveUIDocument.Document;
            List<XYZ> bottomFacesPts = new List<XYZ>();
            Wall wall = null;
            using (Transaction t = new Transaction(doc, "wall"))
                t.Start();
                doc.ActiveView.DetailLevel = ViewDetailLevel.Fine;
                wall = Wall.Create(doc,
                    Line.CreateBound(XYZ.Zero, new XYZ(10,0,0)),
                    new FilteredElementCollector(doc).OfClass(typeof(Level)).FirstOrDefault().Id,
                    false);
                wall.WallType = new FilteredElementCollector(doc).OfClass(typeof(WallType)).Cast<WallType>().FirstOrDefault(q => q.Name == "Exterior - Brick on CMU");
                t.Commit();
            using (Transaction t = new Transaction(doc, "Place tag"))
                t.Start();
                List<ElementId> ids = new List<ElementId> { wall.Id };
                if (PartUtils.AreElementsValidForCreateParts(doc, ids))
                    PartUtils.CreateParts(doc, ids);
                    doc.Regenerate();
                    foreach (ElementId id in ids)
                        if (!PartUtils.HasAssociatedParts(doc, id))
                            continue;
                        ICollection<ElementId> partIds = PartUtils.GetAssociatedParts(doc, id, truetrue);
                        foreach (ElementId partId in partIds)
                            Element part = doc.GetElement(partId);
                            bottomFacesPts.AddRange(GetBottomFacePoints(part));
                t.RollBack();
            using (Transaction t = new Transaction(doc, "tags"))
                t.Start();
                foreach (XYZ pt in bottomFacesPts)
                    IndependentTag tag = doc.Create.NewTag(doc.ActiveView, wall, true, TagMode.TM_ADDBY_MATERIAL, TagOrientation.Horizontal, pt);
                    tag.LeaderEnd = pt.Add(new XYZ(0.100));
                    tag.TagHeadPosition = pt.Add(new XYZ(-20,0));
                t.Commit();
                public List<XYZ> GetBottomFacePoints(Element e)
            List<XYZ> resultingPts = new List<XYZ>();
            FaceExtractor faceExtractor = new FaceExtractor(e);
            FaceArray faces = faceExtractor.Faces;
            if (faces.Size == 0) { return resultingPts; }
            foreach (Face face in faces)
                PlanarFace pf = face as PlanarFace;
                if (pf == null) { continue; }
                if (pf.Normal.IsAlmostEqualTo(XYZ.BasisZ.Negate()))
                    EdgeArrayArray edgeLoops = face.EdgeLoops;
                    foreach (EdgeArray edgeArray in edgeLoops)
                        foreach (Edge edge in edgeArray)
                            Line line = edge.AsCurve() as Line;
                            if (line == null)
                                continue;
                            if (!line.Direction.IsAlmostEqualTo(XYZ.BasisY) &&
                                !line.Direction.IsAlmostEqualTo(XYZ.BasisY.Negate()))
                                continue;
                            XYZ end0 = line.GetEndPoint(0);
                            XYZ end1 = line.GetEndPoint(1);
                            if (end0.X > 1)
                                continue;
                            Line ll = Line.CreateBound(end0, end1);
                            //List<XYZ> points = edge.Tessellate() as List<XYZ>;
                            resultingPts.Add(ll.Evaluate(0.5true));
           public class FaceExtractor
            private Element _element;
            private Document _doc;
            private Autodesk.Revit.ApplicationServices.Application _app;
            private Autodesk.Revit.Creation.Application _appCreator;
            private Transform _matrix;
            private FaceArray _faces;
            /// <summary>
            /// Gets the transform for element
            /// </summary>
            public Transform Matrix
                get { return _matrix; }
            /// <summary>
            /// Gets faces
            /// </summary>
            public FaceArray Faces
                get { return _faces; }
            /// <summary>
            /// Default constructor
            /// </summary>
            /// <param name="element">element</param>
            public FaceExtractor(Element element)
                _element = element;
                _doc = element.Document;
                _app = _doc.Application;
                _appCreator = _app.Create;
                GetFaces();
            /// <summary>
            /// Retrieve all faces from the
            /// given element's geometry solid.
            /// </summary>
            private void GetFaces()
                Options geoOptions = _appCreator.NewGeometryOptions();
                geoOptions.ComputeReferences = true;
                GeometryElement geoElem = _element.get_Geometry(geoOptions);
                _faces = GetFacesFrom(geoElem);
            /// <summary>
            /// Retrieve all faces from the first solid
            /// encountered in the given geometry element.
            /// </summary>
            /// <param name="geoElement">geometry element</param>
            /// <returns>faces</returns>
            public FaceArray GetFacesFrom(GeometryElement geoElement)
                foreach (object o in geoElement)
                    Solid geoSolid = o as Solid;
                    if (null == geoSolid)
                        GeometryInstance instance = o as GeometryInstance;
                        if (null == instance)
                            continue;
                        GeometryElement geoElement2 = instance.SymbolGeometry;
                        _matrix = instance.Transform;
                        if (geoElement2 == null)
                            continue;
                        if (geoElement2.Count() == 0)
                            continue;
                        return GetFacesFrom(geoElement2);
                    FaceArray faces = geoSolid.Faces;
                    if (faces == null)
                        continue;
                        continue;
                    return geoSolid.Faces;
                return null;
Replies (24)
Message 21 of 25
jeremy_tammik
... still digging for this...
Message 22 of 25
julianX4N5F
Message 23 of 25
Julian.Wandzilak
I had a similar problem in my toolbar (I hope to see it this week on Autodesk App Store – proud developer 😊). In one of my scripts, I wanted to list all empty material tags.
To the best of my knowledge in some cases “standard way” (Moving, view refreshing etc) does not work with some material tags and they still show empty. I didn’t find out why it is happening, but my script had the problem with the same material tags – In presentation project from Revit 2024 I had a problem with I think 25% of material tags. I think that moving them manually helped them – doing it automatic with Revit API for sure didn’t.
To make my script work, I ended up completely rewriting the script. I looked for tags which did not refresh correctly, grouped them by the view, opened the view, added auto closing form (which needed at least 250 milliseconds -> It didn’t work with something super quick). This way, finally the material tags showed the correct values.
Example how it works below (I added some empty tags to the file so there is more than in standard Revit file):
https://drive.google.com/uc?export=view&id=1AxXl-a9nB0w8ji8VJm4NqfAdeAZQktB2
Sorry, for mess. I have too many different accounts on myself (with different licences) 😉
blog: w7k.pl more about me: Linkedin Profile
My add-ins for Revit: Drafter(180+ scripts) & Leveler
Message 24 of 25
jeremy_tammik
The development team says: The missing material tag issue is a known limitation and has not been completely resolved. To tackle this issue, we have implemented a multi-faceted approach. In some situations a short-term solution is feasible. This makes the tracking somewhat confusing for the uninitiated. In cases where a short-term solution is not possible, a Dynamo script can be used as a workaround. Such a script can automatically interact with the material tag and trigger its regeneration, similar to the approaches described above. For a long-term solution, we have initiated a release epic for redesign and research. This solution has undergone review and prioritization with our Product Manager (PM) and Engineering Manager (EM) teams, alongside other initiatives. Although addressing this issue remains a top priority, its complexity has led us to primarily focus on a future Revit release.
Message 25 of 25
dhanait_ajay13
Found any solutions? i have same issue, when Manually making any tweak to the tags ( moving) will get the tag to properly show the material value, but using the API to create the tags is show the blank data.
