Mapping sensor data to Revit elements using API with Python
mostafa.hallaji
mostafa.hallaji
I hope my message finds you well,
I am extending some IFC entities, and I want to use these entities in the Revit application.
These entities contain continuously updating data. For example Pressure Sensor of a pump, data of which is saved in a separate database. I am wondering how I can link/map the continuously updating sensor data to the actual pump in the Revit file? I appreciate your responses in advance.
Kind Regards,
Mostafa.
jeremy_tammik
You can implement a Revit add-in which implements an external event which is triggered by your updated external sensor data and adds it to the affected elements. The Building Coder covered quite a number of such samples, e.g., the RevitWebCam, FireRatingCloud  and other samples connecting the desktop with the cloud:
mostafa.hallaji
Thank you very much Jeremy, I will study the the content of the links and will ask for the clarification if needed.
 Kinds regards,
Mostafa.
