Manage Worksets of a Link
Message 1 of 12
Does anyone know if its possible to get (and set) the Opened property of a Workset in a Linked File via API?  In the UI, this is Manage Links > Manage Worksets button.   (Image attached.)  I would like to create a tool that shows this property of all links in a model.  Thanks.
Replies (11)
Message 2 of 12
Charles.Piro
you can access on linkked workset like this :
foreach (Document _linkdoc in app.Documents)
                    if (!_linkdoc.IsLinked)
                        continue;
                    WorksetTable _worksetTable = _linkdoc.GetWorksetTable();
                    IList<WorksetPreview> lstPreview =  WorksharingUtils.GetUserWorksetInfo(_linkdoc.GetWorksharingCentralModelPath());
                    foreach (WorksetPreview item in lstPreview)
                        Workset wkset = _worksetTable.GetWorkset(item.Id);
                        TaskDialog.Show("rvt", wkset.Name);
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 3 of 12
Thanks so much!  I modified slightly to create a single dialog.  My implementation:
public void GetLinkedWorksets()
			Autodesk.Revit.ApplicationServices.Application app = this.ActiveUIDocument.Application.Application;
			string info = "";
				info += _linkdoc.Title + Environment.NewLine;
                    continue;
                    if (wkset.IsOpen)
                    	info += wkset.Name + ": Open" + Environment.NewLine;
                    else
                    	info += wkset.Name + ": Closed" + Environment.NewLine;
                info += Environment.NewLine;
			TaskDialog.Show("Info", info);
Now to figure out if i can set the property using WorksetConfiguration.Close() and Open() methods.
Message 4 of 12
Charles.Piro
you can open or close workset like this :
public Result Execute(ExternalCommandData extCmdData, ref string msg, ElementSet elmtSet)
            UIApplication uiapp = extCmdData.Application;
            UIDocument uiDoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uiDoc.Document;
            try
                List<WorksetId> lstWkSet_Open;
                List<WorksetId> lstWkSet_Close;
                List<Element> lstRvtLinkType = new FilteredElementCollector(doc).OfClass(typeof(RevitLinkType)).ToList();
                        continue;
                    RevitLinkType _RvtLinkType = null;
                    foreach (Element elmnt in lstRvtLinkType)
                        _RvtLinkType = elmnt as RevitLinkType;
                        if (_RvtLinkType.Name != _linkdoc.Title)
                            continue;
                        else
                            break;
                    lstWkSet_Close = new List<WorksetId>();
                    // Or lstWkSet_Open = new List<WorksetId>();
                    WorksetConfiguration wk = new WorksetConfiguration();
                    ModelPath _modelpath = _linkdoc.GetWorksharingCentralModelPath();
                    IList<WorksetPreview> lstPreview = WorksharingUtils.GetUserWorksetInfo(_modelpath);
                        if (!wkset.IsOpen)
                            lstWkSet_Close.Add(wkset.Id);
                            continue;
                        // Or :
                        //if (wkset.IsOpen)
                        //    lstWkSet_Open.Add(wkset.Id);
                        //    continue;
                    _RvtLinkType.LoadFrom(_modelpath, wk);
            catch (Exception e)
                msg = e.Message;
                return Result.Failed;
            return Result.Succeeded;
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 5 of 12
Charles, Thanks but I can't seem to make this code work. You don't seem to be using WorksetConfiguration.Close() method anywhere. I tried adding it to my version and it still won't close for some reason.
Message 6 of 12
Charles.Piro
I forget one line at the end !!!
                        continue;
                            continue;
                        else
                            break;
                        if (!wkset.IsOpen)
                            continue;
                        // Or :
                        //if (wkset.IsOpen)
                        //    continue;
                    wk.Open(lstWkSet_Close);
                    //or
                    //wk.Close(lstWkSet_Open);
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 7 of 12
Rockit_for_Revit
I am trying to do the same thing but close the worksets. When I run my command Revit reloads the link but all the worksets remain open.
                                Dim objWorksetTable As WorksetTable = linkedDoc.GetWorksetTable()
                                Dim objModelPath As ModelPath = linkedDoc.GetWorksharingCentralModelPath()
                                Dim lstPreview As IList(Of WorksetPreview) = WorksharingUtils.GetUserWorksetInfo(objModelPath)
                                Dim lstWkSet_Close As New List(Of WorksetId)
                                For Each objWorksetPreview As WorksetPreview In lstPreview
                                    Dim wkset As Workset = objWorksetTable.GetWorkset(objWorksetPreview.Id)
                                    If wkset.IsOpen Then
                                Next
                                Dim wk As WorksetConfiguration = New WorksetConfiguration
                                wk.Close(lstWkSet_Close)
                                objRevitLinkType.LoadFrom(objModelPath, wk)
Kind Regards
David
Message 8 of 12
PerryLackowski
I am encountering the same problem. Did you ever find a solution?
Message 9 of 12
jeremy_tammik
I asked the development team for you...
Message 10 of 12
Rockit_for_Revit
Kind of,
I ended up using this:
RevitLinkType.LoadFrom(objExternalResourceReference, WorksetConfiguration)
Kind Regards
David
Message 11 of 12
PerryLackowski
I figured it out in this similar post.
You need to construct the WorksetConfiguration like this to close worksets.
        workset_config = WorksetConfiguration(WorksetConfigurationOption.CloseAllWorksets)
        workset_config.Open(open_this_list_of_worksets)
I originally tried the code below, and it did not work - it left all the Worksets open. Seems like maybe a bug? That or the API just isn't clearly explaining how the WorksetConfiguration Class works...
        workset_config = WorksetConfiguration(WorksetConfigurationOption.OpenAllWorksets)
        workset_config.Close(close_this_list_of_worksets)
So to close Worksets, you need to create a list of the Worksets that you want to remain open.
Message 12 of 12
jeremy_tammik
This vaguely matches the development team's guess, which says:
I think you need to couple the workset unloading with a reload operation by using RevitLinkType.ReloadFrom( path, WorksetConfiguration ) that will let you specify the list of worksets which should be open after the load.
The similarity lies in the words 'specify the list of worksets which should be open'...
