Making API for energy calculation, unable to "Set Parameters for certain walls to certain directions"
allazaruszcheong_21
Message 1 of 24
allazaruszcheong_21
Developing RevitAPI, calculating net energy transfer by a bulidng, it involves the directions of the walls, it works on a simple model, but not a more complicated real life model. Need help.
//Checking for SouthWest Facing Walls & Windows
bool isSouthWestFacing = IsSouthWestFacing(exteriorDirection);
if (isSouthWestFacing)
SouthWest_Wall_Lst.Add(WE);
inserts_0 = (WE as HostObject).FindInserts(true, true, true, true);
ParaSouthWestWall = WE.LookupParameter("SouthWest");
using (Transaction trans = new Transaction(doc, "ETTV_1"))
trans.Start();
ParaSouthWestWall.Set(1);
foreach (ElementId emtid in inserts_0)
Element emt = doc.GetElement(emtid);
emt.LookupParameter("SouthWest").Set(1);
trans.Commit();
the first error occurs when i try to set(1) the SpecialParameters "southwest" to a checkbox
Replies (23)
Message 21 of 24
allazaruszcheong_21
Hi update, there were missing parameters under the Text header, i have added them as global parameters
these are no longer an issue however a new issue arose being that being at line 1591
this is the error that pops up.
Anybody help?
Message 22 of 24
ctm_mka
First, Check that what is being dim'd as a wall, is actually a wall, and not null. Second, if it is a wall, try get parameter from the element (e) instead of the wall.
Message 23 of 24
allazaruszcheong_21
They are walls...
Message 24 of 24
ctm_mka
apologies, let me rephrase that, when your code gets to line 1589, verify that wall is not null.
