MACRO TO CLEAN UP SHEET WITH DRAFTING VIEW IN REVIT (USING VB.Net)
Hello All,
I am trying to create a macro that
1. Activates a viewport on sheet which contains a drafting view ( or recursively asks user to select sheet and viewport to modify and then activates that viewport)
2. Selects all elements of the drafting view
3. Filters out all the horizontal lines and sends to back
4. Filters out all the detail items and brings to front
5. Filters out all detail item tags and brings to front
6. keeps all vertical lines where they are
Any Ideas how to do this.
jeremytammik
Activating a view and selecting specific elements in it is easy to do programmatically.
I am not so certain about the sending to front and back.
Does Revit support that at all?
In any case, the way to proceed to solve a programming task in the Revit API is always to research for an optimal workflow and best practices manually in the user interface first.
Once that approach is totally is clear, you can start implementing your macro.
Jeremy Tammik
Developer Technical Services
The Building Coder
Hello Jeremy Tammik
Thankyou for your reply.
I was able to change the draw order of the elements within revit api. However, I am stuck on another front.
How does one filter out lines by Linestyles on a sheet
so basically how does one group lines based on their linestyle
Any ideas
Mithun Cherian
stever66
With a filtered element collector.  See if this post from Jeremy helps:
https://thebuildingcoder.typepad.com/blog/2016/10/how-to-create-a-new-line-style.html
once you know you need a filtered element collector, this was the 3rd result of a search for:
filteredelementcollector linestyles revit api
Hello stever66,
Unfortunately linestyle it seems is a subcategory of ost_lines and a type of graphicstyle class
Let say I am able to create a list of all gŕaphicstyles or linestyles in the viewport
For each curveelements, i need to loop through the distince linestyles and add that curveelement to a distinct list corresponding to the linestyle it belongs to.
How would i create a list<elements> corresponding to each distinct linestyle
int i = 0;
ICollection<GraphicsStyle> gas = new List<GraphicsStyle>();
                foreach (CurveElement cv in LineCollect)
               if (gas.Contains(cv.LineStyle))
                    else
                        gas.Append(cv.LineStyle);
                foreach (GraphicsStyle gs in gas)
                    IList<Element> listy[i] = new List<Element>();
                        foreach (CurveElement cv1 in LineCollect)
                            if (cv1.LineStyle==gs)
                                listy[i].add(cv1);
                        i=i+1;
the syntax is probably wrong. can you declare lists of type list[0], list[1] and so forth?
