Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Macro module initialization failed. Revit 2025
5 REPLIES 5
halukuzuner
419 Views, 5 Replies
I think this forum is more suitable than the others for this question.
I am getting the error in the picture below. I already reinstalled Revit. But nothing changed. Is there anybody who knows solution?
5 REPLIES 5
jeremy_tammik
in reply to: halukuzuner
Yup, I agree this forum makes sense for this question. However, I cannot hazard any guess on what might be causing the error you see. Although, if I try really hard, it may be due to the macro trying to do something that fails during its initialisation. One potential thing it might be trying to do is load some .NET assembly DLL that it depends on, and that it can access in previous releases but not in Revit 2025. However, without further details, it is impossible to say anything whatsoever for sure.
admaecc211151
Can you edit the Macro in your macro manager?
Maybe you can get more exact failed message in there.
halukuzuner
in reply to: admaecc211151
When I edit and run sample macros, I get error in the picture below.
ricaun
The error looks like is something in the visual studio code. You could use the Visual Studio 2022, at least I know that works by default.
https://forums.autodesk.com/t5/revit-api-forum/revit-2025-macro-manager-and-visual-studio-2022/td-p/...
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
halukuzuner
in reply to: ricaun
Hi ricaun,
I uninstalled and reinstalled VScode it worked.
I also tried running Visual Studio as Macro editor as you mentioned. It also worked.
Thanks for your reply.
Rail Community
