macro disappear
macro disappear
Message 1 of 14
macro disappear
im tryin to create pipe by using the code below, i built the solution wit no errors but te macro disappear !! i dont know why,, can anyone elp me please
public Pipe CreateNewPipe(Document document, ElementId systemTypeId, ElementId levelId)
    // find a pipe type
    FilteredElementCollector collector = new FilteredElementCollector(document);
    collector.OfClass(typeof(PipeType));
    PipeType pipeType = collector.FirstElement() as PipeType;
    Pipe pipe = null;
    if (null != pipeType)
        // create pipe between 2 points
        XYZ p1 = new XYZ(0, 0, 0);
        XYZ p2 = new XYZ(10, 0, 0);
        pipe = Pipe.Create(document, systemTypeId, pipeType.Id, levelId, p1, p2);
    return pipe;
Replies (13)
Message 2 of 14
FAIR59
a macro has this form:
        public void myMacro()
returntype void, no parameters.
using your method, the macro could be something like this:
		public void CreatePipe()
			Document doc = this.ActiveUIDocument.Document;
			List<Level> levels = new FilteredElementCollector(doc)
				.OfClass(typeof(Level))
				.Cast<Level>()
				.ToList();
			ElementId levelId = levels.FirstOrDefault().Id;
			List<PipingSystemType> pipesystems = new FilteredElementCollector(doc)
				.OfClass(typeof(PipingSystemType))
				.Cast<PipingSystemType>()
				.ToList();
			if (pipesystems.Count==0) return;
			ElementId systemtype = pipesystems.FirstOrDefault().Id;
			Pipe newPipe = CreateNewPipe(doc,systemtype ,levelId);
			this.ActiveUIDocument.Selection.SetElementIds(new List<ElementId>() {newPipe.Id});
Note: if you want to change the document, you have to use a TransAction.
Message 3 of 14
Dear Fair59 thank you for your kind response
im learning revit API using the link below but after finishing the code i build it and it show no errors but the macro disappear from the module
http://www.revitapidocs.com/2015/9550265f-5760-3c28-d023-d0373285855b.htm
i tried your code but it gives me three errors:
'a.ThisDocument' does not contain a definition for 'ActiveUIDocument' and no extension method 'ActiveUIDocument' accepting a first argument of type 'a.ThisDocument' could be found (are you missing a using directive or an assembly reference?) (CS1061) - C:\Users\AHMAD\AppData\Local\Temp\{6A873E7C-98CD-47FB-B322-36D28FFAB07B}\Revit\DocHookups4428\1157782784\a\Source\a\ThisDocument.cs:42,24
The name 'CreateNewPipe' does not exist in the current context (CS0103) - C:\Users\AHMAD\AppData\Local\Temp\{6A873E7C-98CD-47FB-B322-36D28FFAB07B}\Revit\DocHookups4428\1157782784\a\Source\a\ThisDocument.cs:54,19
'a.ThisDocument' does not contain a definition for 'ActiveUIDocument' and no extension method 'ActiveUIDocument' accepting a first argument of type 'a.ThisDocument' could be found (are you missing a using directive or an assembly reference?) (CS1061) - C:\Users\AHMAD\AppData\Local\Temp\{6A873E7C-98CD-47FB-B322-36D28FFAB07B}\Revit\DocHookups4428\1157782784\a\Source\a\ThisDocument.cs:55,9
Message 4 of 14
FAIR59
I don't use macro's often, but I think this should be the structure of the module.
public partial class ThisApplication
		private void Module_Startup(object sender, EventArgs e)
		private void Module_Shutdown(object sender, EventArgs e)
		#region Revit Macros generated code
		private void InternalStartup()
			this.Startup += new System.EventHandler(Module_Startup);
			this.Shutdown += new System.EventHandler(Module_Shutdown);
		#endregion
		public Pipe CreateNewPipe(Document document,ElementId systemTypeId, ElementId levelId)
    			// find a pipe type
    			return pipe;
As you are starting to program, you should search the net for more information on getting started with Macro's. The first site I found is:
http://thebuildingcoder.typepad.com/blog/2015/10/rtc-classes-and-getting-started-with-revit-macros.h...
Message 5 of 14
FAIR59
I see from the errors that you are working on a Document-macro. My previous replies are based on a Application-macro.
in a document-macro
code for the document:  Document doc= this.Document;
code for setting the selection: this.Selection.SetElementIds(new List<ElementId>() {newPipe.Id});
Message 6 of 14
thanks FAIR59
i built the code and it gives me no errors and the macro didnt disappear, i ran the macro but nothing happen on revit,below is the code
 * Created by SharpDevelop.
 * User: ashonnar
 * Date: 6/19/2017
 * Time: 12:18 PM
 * To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.DB.Macros;
namespace a
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.DB.Macros.AddInId("1C724706-132D-46B2-8A14-C7715606378B")]
    public partial class ThisDocument
        #endregion
        public void Createnewpipe()
        public static Pipe Createnewpipe(Document document, ElementId systemTypeId,  ElementId levelId )
    // find a pipe type
    Pipe pipe = null;
        XYZ p1 = new XYZ(10000);
        XYZ p2 = new XYZ(100001000);
    return pipe;
Message 7 of 14
so-chong
Hi, try do something like this ( i have comment some code of yours, because they don't work in a macro environment. Secondly always create a transaction):
       // public static Pipe Createnewpipe(Document document, ElementId systemTypeId,  ElementId levelId )
            Document document = this.ActiveUIDocument.Document;
            UIDocument uidoc = this.ActiveUIDocument;
            ViewPlan view = document.ActiveView as ViewPlan;
            Level level = view.GenLevel;
            // find a pipe system type
            FilteredElementCollector sysCollector = new FilteredElementCollector(document);
            sysCollector.OfClass(typeof(PipingSystemType));
            ElementId pipeSysTypeId = sysCollector.FirstElementId();
            // find a pipe type
            Pipe pipe = null;
                using (Transaction t = new Transaction(document, "Create Pipe"))
                    t.Start();
                    pipe = Pipe.Create(document, pipeSysTypeId, pipeType.Id, level.Id, p1, p2);
                    t.Commit();
         //   return pipe;
Message 8 of 14
FAIR59
I deliberately gave you code, without any codelines, so you could see the structure of a macro.
Now that you haven't any errors anymore, you can start coding the macro. The entry point for the macro is the method
public void Createnewpipe().
At the moment this method is empty, so the macro does nothing.
Message 9 of 14
i dont know what are the problems, i tried all what you said and below is the upper part of the code, maybe something wrong in it, thank you
using System;
using System.Linq;
using Autodesk.Revit.UI.Events;
using Createnewpipe;
using Autodesk.Revit.UI.Plumbing;
Message 10 of 14
so-chong
Hi, try delete this using directive (using Createnewpipe) and rebuild your code in the SharpDevelop editor.
Message 11 of 14
so-chong
 * User: S.Li
 * Date: 22-6-2017
 * Time: 9:19
using System;
using System.Linq;
namespace testPipe
    [Autodesk.Revit.DB.Macros.AddInId("78D0C737-4539-4CA3-B88B-078BFD2773C1")]
		#endregion
                    // find a pipe type
                    Pipe pipe = null;
                         XYZ p1 = new XYZ(100, 0, 0);
                         XYZ p2 = new XYZ(1000, 0, 1000);
                             t.Start();
                             t.Commit();
Message 12 of 14
thank you very much faris
Message 13 of 14
thank you very much sochong
Message 14 of 14
what is the differences between public class and public void ?
