<property# Username on Application>
jagostinho74
jagostinho74
getting
instead of the actual username while using
from pyrevit import ApplicationServices
username = ApplicationServices.Application.Username
print username
any ideas?
Thank you
J
Assistant BIM/CAD Manager
Manchester, UK
TorsionTools
You need to use the UIApplication.
UIApplication uiapp = commandData.Application;
string user = uiapp.Application.Username;
You an use the ApplicationServices method to make sure a user is logged in.
if (Autodesk.Revit.ApplicationServices.Application.IsLoggedIn)
jagostinho74
how can I define "commandData"?
Getting this error.
NameError: name 'commandData' is not defined
Manchester, UK
TorsionTools
That was showing an example of how to get the UIApplication from an ExternalCommand. Just make sure you have the UIApplication and you can get the information you are looking for.
