looping and rotating a curve around axis from an angles list
REDO10
REDO10
Hi all,
I'm writing a python script inside dynamo and I want to rotate a curve from a defined angles list, and I'm  stuck on how to set the rotation function, please check below a part of my code :
# curve to rotate
curv = IN[0][0].ToRevitType()
# circle defining path rotation
out_path = IN[0][1].ToRevitType()
spacing = IN[1]/0.3048
# computing rotation angle
def rebar_rotation(circle, space):
    sweepAngle = (space * 360) / (circle.Radius *  2 * math.pi)
    return sweepAngle
angle = rebar_rotation(out_path, spacing)
# angle count around 360°
count = int(math.ceil(360/angle))
for i in range(0, count):
    a= i*angle
    # I'm stuck to define the rotation function
    rebar_curve = curv.Rotate(Line.CreateBound(XYZ(0,0,0), XYZ(0,0,1)), a)
Thanks for your help in advance
Mohamed_Arshad
HI @REDO10
You need to do circular pattern right ? 158 lines needed?
Mohamed Arshad K
Software Developer (CAD & BIM)
REDO10
@Mohamed_Arshad @Organon
yes that exactly what I need
Mohamed_Arshad
HI @REDO10
You have to use some geometry concepts to solve this, you can use two geometry concepts
01. Rotation Transformation
02. Trignometry Functions
Kindly refer to the below code and a reference image for an Idea.
Rotation Transformation Sample Code:
            #region Rotate Curve To 158 Times
            Line line = verticalLine;
            XYZ centerPoint = arc.Center;
            double angleinDeg = 360d / 158d;
            using (Transaction createArray = new Transaction(revitDoc, "Create Array"))
                createArray.Start();
                for (int i = 1; i <= 158; i++)
                    double angleinRad = (angleinDeg * Math.PI) / 180;
                    Transform rotationTransform = Transform.CreateRotationAtPoint(XYZ.BasisZ, angleinRad, centerPoint);
                    Curve c = line.CreateTransformed(rotationTransform);
                    //Create Sketch Plane
                    XYZ normal = XYZ.BasisX.CrossProduct(line.Direction);
                    Plane p = Plane.CreateByNormalAndOrigin(normal, c.GetEndPoint(0));
                    SketchPlane skp = SketchPlane.Create(revitDoc, p);
                    revitDoc.Create.NewModelCurve(c, skp);
                    angleinDeg +=360d/158d;
                createArray.Commit();
            #endregion
Kindly understand the logic behind the code and try to apply it in your Program using Python. Above program will create a Model Line array in the circular form.
Reference Image (Rotation Transformation):
Trigonometry Function Concept:
https://www.mathsisfun.com/geometry/unit-circle.html#:~:text=Try%C2%A0It%C2%A0Yourself,negative%20va...
Hope this will helps 🙂
Mohamed Arshad K
REDO10
@Mohamed_Arshad
Thanks for your solution...I know there are plenty thought solutions!!
I never worked with C#, I'm using Python and I solved my issue by correcting the error I made in my initial script, where I used CreateRotation Method  (sometimes a stupid mistake costs you all day!!)
here my corrected code:
import sys
import clr
import math
import System
from System.Collections.Generic import IList, List
clr.AddReference('RevitAPI')
import Autodesk
from Autodesk.Revit.DB import *
from Autodesk.Revit.DB.Structure import *
clr.AddReference('RevitNodes')
import Revit
clr.ImportExtensions(Revit.GeometryConversion)
clr.AddReference('RevitServices')
import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
doc = DocumentManager.Instance.CurrentDBDocument
cover = IN[1]/0.3048
rebar_type = UnwrapElement(IN[2])
Hook_type = UnwrapElement(IN[3])
host= UnwrapElement(IN[4])
spacing = IN[5]/0.3048
# compute the angle rotation
    return sweepAngle
# rotated rebars count
rebars = []
    a= i*angle
    rot = Transform.CreateRotation(XYZ.BasisZ, a*2*math.pi/360)
    rot_curve = curv.CreateTransformed(rot)
    rebars.append(rot_curve.ToProtoType())
OUT = rebars
Thanks again.
