Location of Assembly containing new Revit 2024 icons
schipmanU5A9G
schipmanU5A9G
I have been using the icons from the UIFrameworkRes.dll located at C:\Program Files\Autodesk\Revit #### for use in my add-in. However, if you de-compile the version of this dll that comes with Revit 2024, it seems to still contain only the pre-2024 icons. Does anyone know where the new icons introduced in 2024 might be kept?
ricaun
Still inside the UIFrameworkRes but in a different folder (ThemedImages) because of the light/dark theme.
The images in png for 16 and 32, each with light and dark theme.
Something like this:
Image: pack://application:,,,/UIFrameworkRes;component/Ribbon/ThemedImages/line_all_views_draw/line_all_views_draw_16_light.png
Image: pack://application:,,,/UIFrameworkRes;component/Ribbon/ThemedImages/line_all_views_draw/line_all_views_draw_32_light.png
Image: pack://application:,,,/UIFrameworkRes;component/Ribbon/ThemedImages/line_all_views_draw/line_all_views_draw_16_dark.png
Image: pack://application:,,,/UIFrameworkRes;component/Ribbon/ThemedImages/line_all_views_draw/line_all_views_draw_32_dark.png
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
schipmanU5A9G
Ah, but now I can no longer have a .ico which will automatically use a different size / theme color as appropriate...
ricaun
Yes, Autodesk dropped the .ico for some reason inside Revit ribbon images.
Maybe in the future will be a .tiff file to support high resolution displays.
