Local file creation problem
Hello, I have a problem creating a local file with a central file.
Anyone in my office can work with a local file and synchronize with the central file.
We have the same edition, Revit 2020.2 and we are on the same server.
I disabled my firewall, I added .rvt and other permissions, but i am not able to create a local file.
The opposite effect, if I make a central file, I am the only one who can make a local file.
TripleM-Dev.net
I would post this in the Revit Architecture Forum .
But sounds like you'r not accessing the local file from the same path.
G:\Project\Revit\Revit_CF2020.rvt
OR
\\ShareG\Project\Revit\Revit_CF2020.rvt
Isn't allowed and considered a different central file, everyone MUST access the central file from the same path.
See the sync settings if the path is different.
- Michel
Thanks, but it doesn't work.
I was looking for the link, the correct address as you suggested, but it does not work.
it's written: File not saved
TripleM-Dev.net
What, G:\Project\Revit\Revit_CF2020.rvt? it's just a sample adress.
Ask your colleagues the full adress to the Central file and create the local from that location!
If you can't access the adress you're colleagues are using then ask the IT department to setup the correct drive/path.
- Miche;
I know that it's just a sample adress. I'm using the correct address for our project.
It's a weird problem.
TripleM-Dev.net
Ok, and when you have created the Local File, next look at the syncronization setting; which path is displayed to the central file, the one used or another one.
If it's another path:
1. Close Revit
2. clear you're temp file (Type %Temp% in win explorer adress)
3. delete (or move) all you're local files (of the project) and belonging subfolders (name of local + "_backup" behind it)
- Michel
jeremytammik
Dear Daniel,
Thank you for your query.
However, just as Michel already pointed out, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
