Loading the macro failed with student version
I am using the Revit 2016 Student Version. And I installed the Revit SDK 2016.
I opened the Macro Manager and created a module. But Create Macro is not active and the module gives an error message with red "X": "Loading the macro failed. Rebuilding the module may resolve this issue."
I searched the error message and found a solution, it says that do Build > Build Solution. (http://archsmarter.com/rebuild-revit-macro/)
But it did not work. I attached the screen shot)
Isn't it able to use macro for Student Version of Revit???
Regards
augusto.goncalves
I'm not aware of any limitations on student version (and it should be the same, except for a different license)
Do you have another machine to test it? Maybe a trial version?
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Hi Augusto,
i tried on a regular licensed machine and it worked.
Also I tried another student version Revit on another machine but it didn't worked again.
Deniz
