Loading Printing Set.
 Hi All,
Any idea about how to set existing printing set as active printing set after clicked from combo box list.
it is succussfully loading all existing printing set in cobo box but bit confused in set as active printing set in api.
Thanks in advance.
Regards
Mass.R
Mustafa.Salaheldin
I guess you need to use PrintSetup.CurrentPrintSetting property.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Hi Thanks for reply,
By using this code i am accessing all printing set can you tell me where can i change the printing setting.
List<string> list = new List<string>();
IList<ViewSheetSet> vsheetsets = new FilteredElementCollector(document)
.OfClass(typeof(ViewSheetSet)).Cast<ViewSheetSet>().ToList();
foreach(ViewSheetSet vs in vsheetsets)
if (!comboBox1.Items.Contains(vs.Name)) comboBox1.Items.Add(vs.Name);
Mustafa.Salaheldin
For the form code:
using Autodesk.Revit.DB;
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
namespace RevitAddinCS5
    public partial class Form1 : System.Windows.Forms.Form
        Document _CachedDoc;
        public Form1(Document CachedDoc)
            InitializeComponent();
            _CachedDoc = CachedDoc;
        private void Form1_Load(object sender, EventArgs e)
            List<ViewSheetSet> vsheetsets = new FilteredElementCollector(_CachedDoc)
            BindingSource bindingSource1 = new BindingSource();
            bindingSource1.DataSource = vsheetsets;
            cb.DataSource = bindingSource1.DataSource;
            cb.DisplayMember = "Name";
            cb.ValueMember = "Views";
        private void Print_Click(object sender, EventArgs e)
            try
                PrintManager printManager = _CachedDoc.PrintManager;
                printManager.PrintRange = PrintRange.Select;
                ViewSheetSetting viewSheetSetting = printManager.ViewSheetSetting;
                viewSheetSetting.CurrentViewSheetSet.Views = cb.SelectedValue as ViewSet;
                printManager.SubmitPrint();
            catch (Exception ex)
                MessageBox.Show(ex.Message);
For the External Command:
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.Collections;
using System.Windows;
using System.Windows.Media.Imaging;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                Form1 frm = new Form1(CachedDoc);
                frm.Show();
                return Result.Succeeded;
                msg = ex.ToString();
                return Result.Failed;
        #endregion
If this works fine with you don't forget to mark the reply as an answer.
¯\_(ツ)_/¯
Mustafa Salaheldin
If you dont can you attach the VS file for my reference and it will help me alot to understand more about coding.
Mustafa.Salaheldin
Here you are Smiley Very Happy
¯\_(ツ)_/¯
Mustafa Salaheldin
