LoadFamily Method Exceptions
ahmadmahrous_1
ahmadmahrous_1
As per API Documentation for: LoadFamily Method (Document, IFamilyLoadOptions) at this page:
https://www.revitapidocs.com/2021.1/cb950c8e-f440-c6db-8563-d1dd16ef3fee.htm
Autodesk.Revit.Exceptions InvalidOperationException may be raised when "the load was cancelled due to a conflict and a False return from one of the interface methods".
What is this mean?
Thank you
bhprest
Someone please correct me if this is wrong.
LoadFamily() takes two arguments:
  1. a target document
  2. class that inherits from the IFamilyLoadOptions interface
The IFamilyLoadOptions interface has two methods, both have a bool return value. Revit uses these two methods to execute some user-defined code prior to loading the family. This exception will be thrown if either of these methods return false.
Hope this helps.
