Loaded Assembly Code File and Load another file
c_hanschen
c_hanschen
There is a nice post for reading All Assembly Codes, Key and Description:
https://forums.autodesk.com/t5/revit-api-forum/how-to-get-all-assembly-codes-and-descriptions/m-p/10...
This gives the basic information for accessing the AssemblyCodeTable.
With the help of RevitLookup I found a way to read the FileName of the loaded Assembly Code File:
Dim MyAssemblyCodeTable As AssemblyCodeTable = AssemblyCodeTable.GetAssemblyCodeTable(MyDoc)
Dim MyExternalResourceReference As ExternalResourceReference = MyAssemblyCodeTable.GetExternalResourceReference(ExternalResourceTypes.BuiltInExternalResourceTypes.AssemblyCodeTable)
Dim FilePath As String = MyExternalResourceReference.InSessionPath
This works for me!
But how can I change the Assembly Code File with the Revit API? In case I want to load another file?
Thanks in Advance,
Chris Hanschen
LKSVDD architecten
The Netherlands
c_hanschen
I searched the internet for over an hour to find a solution, searched the Revit Api Forum also of course, but did not found a solution. So I posted this question here!
I thought, I will give it one more internet search and found the solution, I will share it here for you all 🙂
Dim p As ModelPath = ModelPathUtils.ConvertUserVisiblePathToModelPath("C:\tabel1.txt")
Dim s = ExternalResourceReference.CreateLocalResource(MyDoc, ExternalResourceTypes.BuiltInExternalResourceTypes.AssemblyCodeTable, p, PathType.Absolute)
Dim MyKeyBasedTreeEntriesLoadResults As New KeyBasedTreeEntriesLoadResult
MyAssemblyCodeTable.LoadFrom(s, MyKeyBasedTreeEntriesLoadResults)
Good luck with this in case you need it 🙂
Chris
