List all view scale on current sheet
stefano.cartaKGT96
Message 1 of 8
stefano.cartaKGT96
Hi guys..
I would to make a list of all view on the current sheet and find relative view scale.
 csheet = doc.ActiveView
 For Each vw As Viewport In csheet.view
  Next
I thinking to use this..but  csheet.view is not correct..
Where I can find a sample? What approch I have to follow?
thanks
Stefano
Replies (7)
Message 2 of 8
ridaabderrahmane
First cast your active view to a ViewSheet using :
var sheet = doc.ActiveView as ViewSheet
then use sheet.GetAllPlacedViews() to find the views placed on your sheet.
Message 3 of 8
stefano.cartaKGT96
thanks!!
some like this? but how  can read the scale of vw?
  Dim CTAV As ViewSheet = doc.ActiveView
  Dim LISTVIEW As IList(Of Viewport) = CTAV.GetAllPlacedViews()
        For Each vw As Viewport In LISTVIEW
        Next
Message 4 of 8
ridaabderrahmane
view.Scale
Message 5 of 8
stefano.cartaKGT96
sorry..but I have problem with the view.scale
in the for each I can't utilize viwp.scale because scale is not a member of viwp
        Dim LIST As IList(Of Viewport) = CTAV.GetAllPlacedViews()
        For Each viwp As Viewport In LIST
        Next
Message 6 of 8
peteregan
I work in C# - I think this is it:
		Dim view as View = doc.GetElement(viwp.OwnerViewId)
		Dim sc as Double = view.Scale
	Next
Message 7 of 8
TripleM-Dev.net
Hi @stefano.cartaKGT96 ,
GetAllPlacedViews  returns a list (Iset) of Elementid's not Viewport elements
See fragment below, this retrieves all unique scales.
If TypeOf (doc.ActiveView) Is ViewSheet Then
	Dim VS As ViewSheet = CType(doc.ActiveView, ViewSheet)
	Dim ViewScales As New List(Of Integer)
		For Each ViewId As ElementId In VS.GetAllPlacedViews
			Dim ViewElem As View = CType(doc.GetElement(ViewId), View)
			Dim Scale As Integer = ViewElem.Scale
			If Not (ViewScales.Contains(Scale)) Then ViewScales.Add(Scale)
		Next
	'ViewScales.Distinct 'Or use distinct after all scales are added.
 - Michel
Message 8 of 8
stefano.cartaKGT96
Hi...
Tomorrow I will try your code...
