Linking Revit Files by Shared Coordinates
I am developing a small plugin for my team. One of the tasks I need to get it working is to be able to link Revit Files. I already manage to link the files using the following method:
public static void LinkNewRVT()
            if (!executeCode) return;
            ModelPath modelPath = ModelPathUtils.ConvertUserVisiblePathToModelPath(linkPath);
            RevitLinkOptions rlOptions = new RevitLinkOptions(false);
            var linkType = RevitLinkType.Create(doc, modelPath, rlOptions);
            var instance = RevitLinkInstance.Create(doc, linkType.ElementId);
However, I cannot figure out how to create the link by Shared Coordinates.  is that option exposed by the API. This is crucial for my plugin to be of any use.
Thanks in advance.
bhprest
Starting in Revit 2018, there is a second constructor for the RevitLinkInstance class which includes the ImportPlacement as an argument:
https://www.revitapidocs.com/2018/8ec3d668-271b-8333-b4d3-b56d50f4ef98.htm
Are you programming for an earlier version?
Thank you mate. Really appreciate your response.
bhprest
No problem!
