So I would like to return whether this box is ticked... [it won't let me insert my screengrab, see attached file :)]
Visibility/Graphic Overrides > Revit Links > Display Settings > Worksets
As you can see, I can return the WorksetVisibility, however this is apparently not the same (which I kind of understand)
Would anyone know of a Method or Property I have missed in the API?
Cheers,
Mark
Solved by jeremytammik. Go to Solution.
The forum seems to be playing up... This should help clarify where we're looking!
Dear Mark,
Thank you for your query.
I didn't notice any 'acting up'.
I did notice that you submitted the same question in another thread, which was also escalated to an ADN case, 15326569 [Linked Workset Visibility In View]:
https://forums.autodesk.com/t5/revit-api-forum/linked-workset-visibility-in-view/m-p/8766417
I repeat the answer I provided there:
Nope, sorry, there is currently no API access to any of the link visibility settings.
If you need this, you might want to submit a request for it on the Revit Idea Station and post a link to it here to gather many votes for it.
Obviously, please check for any existing similar wishes first.
Thank you!
Best regards,
Jeremy
