Linked File Element Intersection Solid Geometry
Message 1 of 12
Hi All,
I have an element e1 with solid s1 and another element which is from linked Revit file/IFC file element e2 with sold s2.
While i am using element intersection filter element e1 return e2 as intersected element so i want to get intersection solid to calculated intersection area.
i used
Solid intersection = BooleanOperationsUtils.ExecuteBooleanOperation(solidA, solidB, BooleanOperationsType.Intersect);
This not return intersection solid.
Summary as below:
Element e1 = Document A
Solid     s1= Document A for element e1
Element e2 = Linked Document element in Document A
Solid     s2= Linked Document element in Document A for element e2
Step 1: Filter intersected element for e1
             result give e2.
Step 2: Perform BooleanOperation to get intersected solid.
             result null.
Any help appreciated.
Replies (11)
Message 2 of 12
jeremytammik
Dear Manish Singh,
You could address this as follows:
You have two solids, A in your main project P and B in your linked project Q.
  • Determine the transformation T from the linked document Q coordinates to P's.
  • Open the linked project Q and retrieve the solid Sb of B.
  • Transform it to P's coordinate space: T * Sb.
  • Retrieve the solid Sa of A.
  • Calculate the intersection of T*Sb with Sa.
Now you can use an element intersection filter based on the intersection result:
http://thebuildingcoder.typepad.com/blog/2018/03/create-2d-arc-and-filter-for-intersecting-elements....
The transformation of Sb can be obtained using the SolidUtils.CreateTransformed method:
http://www.revitapidocs.com/2018.1/22592761-f39c-4f53-d33b-6c21a4fa9d2d.htm
Please let us know whether it works and share a code snippet showing the final result.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 12
Hi Jeremy,
Thanks for reply. I tried as you said above.  please take a look shall i doing anything wrong because still i receive intersection surface area 0.
public static double GetIntersectedSolidArea(Document _host, Solid _hostElement, RevitLinkInstance _rins, Solid _linkedElement)
//Step 1 "Determine the transformation T from the linked document Q coordinates to P's."
Transform _transForm = _rins.GetTransform();
// Step 2 "Open the linked project Q and retrieve the solid Sb of B."
// _linkedElement is Solid of linked Link
// Step 3 "Transform it to P's coordinate space: T * Sb."
Solid _tmp = SolidUtils.CreateTransformed(_linkedElement, _transForm);
// Step 4 "Retrieve the solid Sa of A"
// _hostElement is hostElementSolid
Solid result= BooleanOperationsUtils.ExecuteBooleanOperation(_hostElement, _tmp, BooleanOperationsType.Intersect);
return result.SurfaceArea;
Message 4 of 12
jeremytammik
Dear Manish,
As a next step, it will help if you can visualise what you are doing.
A big help is to create model lines representing the solid edges, e.g., as described here to debug form creation or display a debugging point:
http://thebuildingcoder.typepad.com/blog/2009/07/debug-geometric-form-creation.html
http://thebuildingcoder.typepad.com/blog/2012/10/display-a-geometry-debugging-point-in-the-model.htm...
Then you can first verify that the transform really achieves what you expect it to.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 5 of 12
Hi Jeremy,
Again i wanted to say thanks for response. But still i am stuck at same point. I attached Code, Revit File & Manifest File. Please take a look what i did wrong so not able to get the exact result. This will help me lot. I am using revit 2018.
"Clash_Example_Project_r2017_Test.rvt" file is main file.
For related element please see this pic.
Message 6 of 12
Hi Jeremy finally i got solution . there is only one change in my case have to use element transformation of linked element instead of Linked file.
Message 7 of 12
jeremytammik
Dear Manish,
Congratulations on solving this and thank you for letting us know!
Could you provide minimal code snippets before and after the fix you applied to demonstrate exactly what you mean, please?
I discussed a related issue in the meantime and am planning a blog post describing the solution for that case, which I thought would help you as well.
Now that you have solved it yourself I would love to add your issue to the same blog post.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 12
Hi Jeremy
Sure i will add solution with file within couple of days.
Message 9 of 12
jeremytammik
Here is the full description of another solution for a similar issue:
http://thebuildingcoder.typepad.com/blog/2018/04/using-intersection-filter-with-linked-file.html
However, it uses:
  Dim transform As Transform = linkedfile.GetTotalTransform
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 10 of 12
c_hanschen
will you still share your solution?
thanks in advance.
chris
Message 11 of 12
BIM_S_S
I their any updates regarding sharing your code sample.
Because i have the same issue.
Thank You
@Anonymous wrote:
Hi Jeremy
Message 12 of 12
BIM_S_S
I need to code sample in c# demonstrate how to detect intersection(clash) between  model  elements  in my files and elements in  linked file elements
