Link revit change - OneDrive
bri47744
bri47744
I'm working in team to a university project in Revit. Currently, we are using OneDrive as cloud for the project, but we all have different path folder. Because we need to link different stuffs in it, we are having problems. What I think could possibly resolve the problem is using an environmental link like %OneDrive%\Project\folder but Revit doesn't permit me to edit the link path so I'm stuck.
Any tips?
jeremy_tammik
I would not try to fight the system. I recommend always trying to use the simplest solution that works. Maybe, in this case, you could set up a special drive X: or L: or something on your Windows OS:
https://duckduckgo.com/?q=map+drive+on+pc
Every participant could use the same drive letter. Then you could use individual batch files for each collaborator to map that drive to the individual OneDrive locations. Would that work?
bri47744
It's the solution I looking for... but for me it doesn't work because I'm using a business account and for some reason I can't use the cid.
Anyway I find a solution changing the path of the onedrive folder on my pc. It's ugly but work.
Thank you so much for your help
