Line Style and a Line Pattern
How to get the relationship between a Line Style and a Line Pattern in Ravit API version 2014/15/16
As you can see here a Line Style has a SetLinePatternId so there is your relationship.
http://thebuildingcoder.typepad.com/blog/2016/10/how-to-create-a-new-line-style.html
solvedplus
this is good article for set line pattern
what about retrieving line pattern associated with line style?
there is no GetLinePattern method
what do i miss here?
thanks
solvedplus
i'm very sorry
I figure out where the problem is
I'm using revit 2016
i tried newer version
its working but not all line styles return line pattern
public void GetLineStyleAndPattern()
            UIDocument uidoc = this.ActiveUIDocument;
            Document doc = uidoc.Document;
            Categories categories = doc.Settings.Categories;
            string s = "";
            Element e;
            Category lineCat = categories.get_Item(BuiltInCategory.OST_Lines );
            foreach (Category lp in lineCat.SubCategories.Cast<Category>())
                e = doc.GetElement(lp.GetLinePatternId(GraphicsStyleType.Projection)) as Element;
                if (e != null)
                    s += "Style : " + lp.Name + " pattern : " + e.Name + "\n";
                else
                    s += "Style : " + lp.Name + "\n";
            TaskDialog.Show("test", s);
