Level Bounding box return null
ahmadeltobshy
ahmadeltobshy
Hey everybody i have a small issue i have face hoping someone helping me
i have collected some annotation elements like Levels, ElevationMarker and so on ..
when i snoop these elements using Revit Lookup i found these elements have boundingbox and there are min and max values
but when i try to get these bounding boxes or min/max value in code there are always NullReferenceException
as the image shows below
i also try to assign a view/3Dview to .get_BoundingBox method instead of having null argument but still getting null all the times.
anyone have any idea what this happens?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @ahmadeltobshy ,
The view should be a 3d view.
Could you please try opening the 3d view in the project and use "doc.activeview"?
BoundingBoxXYZ boundingBox = Level.get_BoundingBox(doc.ActiveView) as BoundingBoxXYZ;
if (boundingBox!=null)
XYZ maxPoint = boundingBox.Max;
XYZ minPoint = boundingBox.Min;
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
caroline.gitonga
You could try to pass the document active view
BoundingBoxXYZ bounding = elem.get_BoundingBox(doc.ActiveView);
XYZ max = bounding.Max;
XYZ xYZ = bounding.Min;
From the Revit Doc , it says
If the view box is not known or cannot be calculated, this will return the model box; if the model box is not known, this will return a null reference ( Nothing in Visual Basic)
Carol Gitonga, Developer Advocacy and Support, ADN Open
ahmadeltobshy
Thank You it works for me.
ahmadeltobshy
Thank you i have read revit docs, and by passing a view this returns a value.
