Launch addin when file is dropped in Revit
I am working on an addin to import data from a file type that Revit currently doesn't support. Is there a way to activate my addin and take a file that is being dragged and dropped into the current document?
matthew_taylor
Hi @Anonymous,
If I was looking at doing something like that I would (and did) search for 'drag' (or 'drop', which proved popular) in the Revit API reference. That lead me to http://www.revitapidocs.com/2017/f4561775-33b7-8643-b792-5cc234f7240f.htm
That led me to better search terms, which led me to this blog post (and reference to an SDK example): http://thebuildingcoder.typepad.com/blog/2012/04/drag-and-drop-api.html
There are probably more up-to-date examples, but I'll leave the searching to you.
You'll also have to see whether these methods are appropriate for your needs!
Let us know how you get on. 🙂
Cheers,
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Thank you, Matthew. I had searched prior to posting, but apparently I wasn't searching for the right terms. This should get me going in the right direction.
matthew_taylor
Hi Michael,
No problem.
Sometimes it's just knowing the right words!
Have a good weekend.
Cheers,
-Matt
Cheers,
-Matt
