Known Bug List
Known Bug List
matthew_taylor
Advisor Advisor
Known Bug List
matthew_taylor
I've added an idea to the idea station about 'Known Bugs'. (Link to post)
On it is a list of all of the bugs I've found in Revit 2018 to date, as well as those I have collated from other sources.
Please add any (2018+) bugs you know of there! Giving an up-vote would help the idea get traction also. Smiley Happy
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
AnatolyCEL
matthew_taylor
Thanks @AnatolyCEL, I've added your item to the Ideas post:
https://forums.autodesk.com/t5/revit-ideas/known-bug-list/idc-p/7121429#M8580
Cheers,
-Matt
MarryTookMyCoffe
you can use forbidden char, like '[' ']' in name of SharedParameterElement when you create it with api(image if some one don't believe me)
do not worry it only gonna take Autodesk 5 years to fix bug
matthew_taylor
An FYI on Revit 2018.0.2 fixes.
See updates here:
https://forums.autodesk.com/t5/revit-architecture-forum/known-bug-list/m-p/7137248/highlight/true#M1...
Let me know if any of your bugs are fixed (or note them on the above post yourself).
p.s. Is it my imagination, or did we used to be able to edit posts and get permalinks for individual posts? I certainly don't see those options now. (IE11)
(I know there is such a thing as 'Highlight', but that term means nothing to me. 😉  )
Cheers,
-Matt
