Iupdater doesn't trigger
Gilles.Lagrilliere
Gilles.Lagrilliere
Hello Everyone
I made an updater that changes the systemType when I change my pipeType and vice versa.
but when I change my systemType my pipeType wont change, the updater wont even trigger.
This are my triggers:
        public static void RegisterPipeUpdater(AddInId addinId)
            Pipes pipeUpdater = new Pipes(addinId);
            UpdaterId id = pipeUpdater.GetUpdaterId();
            UpdaterRegistry.RegisterUpdater(pipeUpdater);
            UpdaterRegistry.AddTrigger(id,
                new ElementCategoryFilter(BuiltInCategory.OST_PipeCurves),
                Element.GetChangeTypeElementAddition());
                Element.GetChangeTypeParameter(new ElementId(BuiltInParameter.RBS_START_OFFSET_PARAM)));
                Element.GetChangeTypeParameter(new ElementId(BuiltInParameter.RBS_END_OFFSET_PARAM)));
                Element.GetChangeTypeParameter(new ElementId(BuiltInParameter.RBS_PIPE_OUTER_DIAMETER)));
                Element.GetChangeTypeParameter(new ElementId(BuiltInParameter.ELEM_TYPE_PARAM)));
// It wont trigger when I change this parameter in my project.
                Element.GetChangeTypeParameter(new ElementId(BuiltInParameter.RBS_PIPING_SYSTEM_TYPE_PARAM)));
            UpdaterRegistry.DisableUpdater(id);
It does trigger when I use the 'Element.GetChangeAny()'.
Is this a bug in Revit? Or am I doing something wrong?
ricaun
Should work the 'Element.GetChangeAny()', which I have used in some projects.
Why are you disabling the updater at the end of the method?
I suppose is not gonna trigger if the updater is diabled.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Gilles.Lagrilliere
The updater works if I use 'Element.GetChangeAny(). But I don't wont to trigger the updater with every change.
I'm disabling the updater so that the user can choose to use the updater. If the user want to use the updater he can enable it by clicking on a button.
ridaabderrahmane
Your code seems right to me, as @ricaun suggested you don't need to Unregister the updater at the end of your function.
You can instead Register your updater and add the triggers at the the onStartUp event.
create a static bool variable.
in your updater classe, in the execute function execute only if the static bool variable is true.
And you can handle the value of this static variable on the button click.
This way the updater is always in the Revit plugin, but he will trigger only if the static bool variable is true, which is handled by the user by clicking on a button.
Hope this helps.
