Issue with RevitAddInUtility for Revit 2025-2026 and customized installer
m.vallee
m.vallee
Here I am again with a very old problem coming back (please see https://forums.autodesk.com/t5/revit-api-forum/issue-with-revitaddinutility-for-revit-2019-and-custo...
I am migrating my Revit plugins to versions 2025 and 2026 of the API, and I am struggling with the update of the deployment part in Visual Studio.
My setup project uses another project called "RegisterRevitAddin" to write/delete needed manifest files at the required locations for each installed Revit version, using the RevitAddInUtility DLL (please see this link). So as I've been doing for the last 8 years without any problem, I've changed the reference to RevitAddInUtility to use the new 2026 version, and made a few changes in my custom actions' code to support Revit 2025 & 2026 manifest registrations. Then I've successfully recompiled both projects and tried to execute the installer on my machine. I have the following error : "Error 1001. Unable to load file or assembly 'RevitAddInUtility, Version=26.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependancies. The specified file could not be found."
Again the only difference I see between 2024 and 2025-2026 versions of the DLL is the "processorArchitecture" tag when adding the reference in the C# project : for 2024 it is "MSIL", for 2025 and 2026 it is "AMD64".
Could you please provide us the "MSIL" compil version of the 2026 RevitAddInUtility DLL ?
Thanks for your help.
ricaun
It's kind of hard to know what the problem is without a proper project example with "RegisterRevitAddin" implementation. If you shared some sample project in the GitHub should be helpful.
I actually creates the manifest file and the bundle folder when creating my installation for my Revit plugins. I'm not using the RevitAddInUtility.dll and PackageContentsParser.dll.
I use this package Autodesk.PackageBuilder and I created that library to basically make the same thing, create the manifest file for Revit and the bundle (PackageContents.xml) for my Revit applications.
Actually I recent update the package to support manifest for Revit and Inventor, and bundle for AutoCAD, Revit, 3ds Max, Inventor, Maya, and Navisworks.
The project is open source.
And you could create the RevitAddin.addin like this:
var builder = BuilderUtils.Build<RevitAddInsBuilder>(builder =>
    builder.AddIn.CreateEntry("Application")
        .Name("RevitAddin")
        .AddInId("11111111-2222-3333-4444-555555555555")
        .Assembly("RevitAddin.dll")
        .FullClassName("RevitAddin.App")
        .VendorId("RevitAddin")
        .VendorDescription("RevitAddin");
builder.Build("RevitAddin.addin");
I hope that helps somehow.
See yaa!
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
m.vallee
Thanks for your help but this is not what I need : I don't want to change my way to create manifest files during setup...
I just want to get the MSIL version of the 2026 RevitAddinUtility DLL instead of the AMD64 one...
ricaun
I can't help with that. I know version 2026.0 have a bug in the RevitAddinUtility.dll related with the Context configuration. Was fixed in the 2026.1 Revit release.
Usually is easier and faster to create/use a package instead of waiting Autodesk to do what you want.
