Isolate element temporarily
office
office
Are there any limitations known to "View.IsolateElementsTemporary Method "
my code:
for i in elements:
	elemId = i.Id
	ids.append(elemId)
ids2 = List[ElementId](ids)
selection = view.IsolateElementsTemporary(ids2)
my elements are nested curtain panels.
when i run my code with walls, it works perfectly
when it comes to nested panels i end up in an empty view
any solutions?
jeremytammik
Dear Koppevi,
Can you temporarily isolate the curtain panels that you are interested in manually in the user interface?
In general, the Revit API will not enable you to do something programmatically that cannot be achieved manually through the Revit product UI.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
office
jeremy, yes, manually everything is removable.
in a standard 3d view, the collection is even marked selected in view and when i manually hide them (using hide selected) they are hidden
thanks peter
ps. what i do is programmed in a python shell within dynamo. could that cause trouble?
conoves
Hello Koppevi -
I was curious about your problem and found that selecting curtain panels directly and choosing "Isolate Elements" results in an empty view (as you found from the API).
I found that choosing the panels, selecting "Isolate Category" and then "Isolate Elements" results in just the selected elements being visible, which is what you want.  You should be able to do something similar with the API.
I suspect this may be a bug in Isolate Elements functionality (the underlying wall category might need to remain "on" to allow the panels to be visible and Isolate Elements may not be doing that).
Thank you,
Scott Conover
Scott Conover
Senior Engineering Manager, Revit
Hello conoves,
Could you provide a small code-sample on how to accieve this? i am also trying to isolate a curtainwall (and all of it's contents) in a 3dview, but i am having trouble (empty view)..
TIA Wouter
office
3 years to fix a bug ......
george1985
Hi @conoves @office ,
I have just tested the python code from the first post - and I can confirm that the bug is still present in Revit 2025:
isolating a Curtain Panel, isolates everything in the active view.
Is it possible to get that workaround code, that Scott Conover mentioned? In any programming language?
I would be very grateful for that.
