Is this property not available in Revit 2025? AllowsVisibilityControl Property
XARMA
XARMA
I can't use AllowsVisibilityControl property.
How do I use it?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @XARMA ,
Yes, it looks like an issue. I found that category.get_AllowsVisibilityControl(doc.ActiveView) determines whether the visibility of a category can be controlled by the user in the current view. I will check why the AllowsVisibilityControl property is mentioned in the documentation.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
GaryOrrMBI
The answer is in the screenshot message:
The programming language used has bearing on which is the correct call.
In Visual Basic the call would be category.AllowsVisibilityControl(doc.ActiveView)
In C# the call would be category.get_AllowsVisibilityControl(doc.ActiveView)
A lot of C# object property calls have this requirement (I'm not a C# developer so I don't know the full details of how, why, when, where, etc)
-G
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
