Is there any way to download Revit 2020.2.9 and SDK.
The lowest version on Autodesk web is Revit 2021.
HI @哀家爆
Kindly check in the below link, Search in the tags and download the version you needed.
URL: https://github.com/jeremytammik/RevitSdkSamples/tags
Hope this helps 🙂
Hi @哀家爆,
You can follow the steps listed in the link below to download the previous Revit versions.
https://www.autodesk.com/support/download-install/individuals/configure-install/download-previous-ve...
Developer Advocacy and Support, ADN Open
I require the latest update for Revit 2020 (2020.2.9). I can longer get this update from the Autodesk portal as it only supports 5 years. Can someone provide me with a link to get this update?
