Is there any way to change wall's profile through Revit API ?
Hi all,
Does anyone know how to change a wall's profile thru Revit API?
Is it supported?
Thanks in advance.
jeremytammik
Dear Basten,
Can you do that in the user interface?
How?
Do you change the wall type, or assign a profile to it, or what?
They API will probably enable you to do either.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
I would like to know that to!
Jeremy, the function works like this:
you select the wall, press edit profile on the modify wall tab, and you edit the walls profile (as seen along the length of it). The editor is like the floor editor.
You draw a closed polyline that the wall then follow.
Regards
Erik
Dronov.Dmitry
Is revitAPI can give us coordinates of this lines?
BardiaJahan
The old deleting trick is the best available workaround, I believe:
http://thebuildingcoder.typepad.com/blog/2010/11/access-to-sketch-and-sketch-plane.html
