Is there any solution to define which equipment connected to certain equipment?
nur91m
nur91m
Hi.
For example, fire alarm system curcuit has one panel and some detectors and they are connected with cable. I want to get detector's id which is connected to the fire panel, then second detector's id which is connected to the first dector and so on. Can I solve this with revit api?
Best Regards
bxw
Have you looked at this sample? It should give you a good start & as always have a look around with the Revit lookup tool.
http://thebuildingcoder.typepad.com/blog/2013/02/simple-mep-system-traversal.html
