Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Is there a way to adjust a witness line gap?
20 REPLIES 20
Message 1 of 21
2403 Views, 20 Replies
Hi.
I'm sorry to post duplicate question, but I can not solve and try to upload again.
I want to adjust dimension's end point.
I created dimensions as follows.
ReferenceArray refArray = new ReferenceArray();
refArray.Append(startLine.Reference);
refArray.Append(endLine.Reference);
var line = Line.CreateBound(point1, point2); Dimension dimension = doc.Create.NewDimension(view, line, refArray);
and I want the end point to be automatically adjusted using api. (like red line)
like this
I have found on the Internet and used Dimension.Segments, but the number of values was 0.
is there a way? I need help.
thank you!
20 REPLIES 20
Message 21 of 21
matthew_conwayN7C2G
@jeremytammik I'm assuming this isn't supported in the API? I've used RevitLookUp before and after I've manually adjusted my Witness Gap without any changes (as others have pointed out, the available parameters are Type parameters). Please let me know so that I can inform our team as to whether or not it is possible.
Thanks!
Autodesk Customer Advisory Groups
Rail Community
