Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Is it possible to listen for when the active view changes?
2 REPLIES 2
Maltezc
618 Views, 2 Replies
Hi all, I have a pretty straight forward question.
As the post title suggests, is there a way to listen for when the active view changes?
The closest thing I can come up with is getting all open UI views but that's not exactly a listener.
Labels (2)
2 REPLIES 2
RPTHOMAS108
in reply to: Maltezc
You probably need to clarify slightly:
A change relating to switching between one view and another
A change of something within the current view
If it's the former then you have UIApplication.ViewActivatedEvent
if it's the latter then  you have  ApplicationServices.Application.DocumentChanged (1) used in combination with FilteredElementCollector (2) set to the current view. Then compare the results of Ids in event args from (1) with that of the filter (2).
TorsionTools
Forma Design Contest
Rail Community
