Is it possible to launch an external exe AND continue to use Revit?
Is it possible to launch an external .exe WinForm from a revit ribbon command panel just like an add-in(I can already do this) and still model and detail in Revit without the wait cursor, which I am taking to be a synchronous lock created by revit or the api.
This below is a code snippit from one of Jeremmy Tammik's blogposts, thanx for the help here Jeremmy, This is invoked from the external app based on JT's blog as well! This helped a great deal in that I could make async calls in my app without dealing with the frailties of the entire revit17 app crashing.
using( Process proc = Process.Start( start ) )
proc.WaitForExit();
rc = proc.ExitCode;
return rc;
 So Have I possibly not implemented the instructions in this link below correctly?
http://thebuildingcoder.typepad.com/blog/2014/07/launching-a-stand-alone-executable.html
If I have is it possible to launch my standalone app and then work in revit in parallel as if the two are in separate universes?
matthew_taylor
Hi @Anonymous,
If I understand you correctly, I think you're overthinking the issue.
Jeremy's example is intending to wait for the external application to exit.
You do not want this (if I understand). So, simply use Process.Start(PathAndFileNameOfExe).
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Yes thanx matt I was, thanx for the rudder.
matthew_taylor
Pleased to help.
Cheers,
-Matt
cxiaoRME8N
Observer
Observer
A follow up: can you call a .bat file instead of an executable? Is there a way to do that?
