Is it possible to create a solid from the edges of Pyramids?
VanQuyet.Doan
VanQuyet.Doan
RPTHOMAS108
Yes you can do so with TessellatedShapeBuilder but you only need the points:
Private Function Obj_230204a(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData,
ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) As Result
        Dim UIApp As UIApplication = commandData.Application
        Dim UIDoc As UIDocument = commandData.Application.ActiveUIDocument
        If UIDoc Is Nothing Then Return Result.Cancelled Else
        Dim IntDoc As Document = UIDoc.Document
        Const NumberOfSides As Integer = 6
        Const BaseRadius As Double = 1
        Const ApexHeight As Double = 2
        Dim Seg As Double = 2.0 / NumberOfSides
        Dim Points As XYZ() = New XYZ(NumberOfSides - 1) {}
        For i = 0 To NumberOfSides - 1
            Dim P As Double = i * Seg
            Dim X As Double = Math.Sin(Math.PI * P) * BaseRadius
            Dim Y As Double = Math.Cos(Math.PI * P) * BaseRadius
            Points(i) = New XYZ(X, Y, 0)
        Next
        Dim builder As New TessellatedShapeBuilder()
        builder.OpenConnectedFaceSet(True)
        'The bottom face
        builder.AddFace(New TessellatedFace(Points, ElementId.InvalidElementId))
        'Side faces
        Dim ApexPt As New XYZ(0, 0, ApexHeight)
        For i = 0 To Points.Length - 1
            Dim J As Integer = i + 1
            If i = Points.Length - 1 Then
                J = 0
            Dim P1 As XYZ = Points(i)
            Dim P2 As XYZ = Points(J)
            builder.AddFace(New TessellatedFace(New XYZ(2) {P1, P2, ApexPt}, ElementId.InvalidElementId))
        Next
        builder.CloseConnectedFaceSet()
        builder.Target = TessellatedShapeBuilderTarget.Solid
        builder.Fallback = TessellatedShapeBuilderFallback.Abort
        builder.Build()
        Dim Res As TessellatedShapeBuilderResult = builder.GetBuildResult
        If Res.Outcome = TessellatedShapeBuilderOutcome.Solid Then
            Using Tx As New Transaction(IntDoc, "Pyramid")
                If Tx.Start = TransactionStatus.Started Then
                    Dim ds As DirectShape = DirectShape.CreateElement(IntDoc, New ElementId(BuiltInCategory.OST_GenericModel))
                    ds.SetShape(Res.GetGeometricalObjects())
                    Tx.Commit()
            End Using
        Return Result.Succeeded
    End Function
public Result Obj_230204a(Autodesk.Revit.UI.ExternalCommandData commandData, ref string message, Autodesk.Revit.DB.ElementSet elements)
            UIApplication UIApp = commandData.Application;
            UIDocument UIDoc = commandData.Application.ActiveUIDocument;
            if (UIDoc == null)
                return Result.Cancelled;
            Document IntDoc = UIDoc.Document;
            const int NumberOfSides = 6;
            const double BaseRadius = 1;
            const double ApexHeight = 2;
            double Seg = 2.0 / NumberOfSides;
            XYZ[] Points = new XYZ[NumberOfSides];
            for (int i = 0; i <= NumberOfSides - 1; i++)
                double P = i * Seg;
                double X = Math.Sin(Math.PI * P) * BaseRadius;
                double Y = Math.Cos(Math.PI * P) * BaseRadius;
                Points[i] = new XYZ(X, Y, 0);
            TessellatedShapeBuilder builder = new TessellatedShapeBuilder();
            builder.OpenConnectedFaceSet(true);
            //The bottom face
            builder.AddFace(new TessellatedFace(Points, ElementId.InvalidElementId));
            //Side faces
            XYZ ApexPt = new XYZ(0, 0, ApexHeight);
            for (int i = 0; i <= Points.Length - 1; i++)
                int J = i + 1;
                if (i == Points.Length - 1)
                    J = 0;
                XYZ P1 = Points[i];
                XYZ P2 = Points[J];
                builder.AddFace(new TessellatedFace(new XYZ[3] {
                P1,
                P2,
                ApexPt
            }, ElementId.InvalidElementId));
            builder.CloseConnectedFaceSet();
            builder.Target = TessellatedShapeBuilderTarget.Solid;
            builder.Fallback = TessellatedShapeBuilderFallback.Abort;
            builder.Build();
            TessellatedShapeBuilderResult Res = builder.GetBuildResult();
            if (Res.Outcome == TessellatedShapeBuilderOutcome.Solid)
                using (Transaction Tx = new Transaction(IntDoc, "Pyramid"))
                    if (Tx.Start() == TransactionStatus.Started)
                        DirectShape ds = DirectShape.CreateElement(IntDoc, new ElementId(BuiltInCategory.OST_GenericModel));
                        ds.SetShape(Res.GetGeometricalObjects());
                        Tx.Commit();
            return Result.Succeeded;
VanQuyet.Doan
hi RPTHOMAS108, thank you for your assistance, I will try it.
jeremy_tammik
Thank you for the beautiful little sample. Shared it on the blog:
https://thebuildingcoder.typepad.com/blog/2023/02/pyramid-builder-commandloader-et-al.html#3
Thank you!
