Invisible lines Style
Im starter in working with revit API and i have a question about the invisible lines style. I want to draw a detail line with this style using API. Is this possible to do that?
matthew_taylor
If you are referring to the style '<invisible lines>' (or something like that), then yes. Just use a filter (filteredelementcollector that looks for a style of that name. I'm unaware of a language independent way of doing that.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Thanks for your reply
this is my code but it doesn't work
public Result Execute(ExternalCommandData revit, ref string message, ElementSet elements)
Document doc = revit.Application.ActiveUIDocument.Document;
Application app = revit.Application.Application;
XYZ st = new XYZ(0, 0, 0);
XYZ end = new XYZ(1000, 1000, 0);
Line geomline = Line.CreateBound(st, end);
View v = doc.ActiveView;
Autodesk.Revit.Creation.Document doc1 = doc.Create;
DetailCurve l1 = doc1.NewDetailCurve(v, geomline);
Categories categories = doc.Settings.Categories;
FilteredElementCollector col = new FilteredElementCollector(doc);
col.OfCategory(BuiltInCategory.OST_InvisibleLines);
l1.LineStyle = (GraphicsStyle)col;
FAIR59
            List<GraphicsStyle> _styles = new FilteredElementCollector(doc)
            .OfClass(typeof(GraphicsStyle))
            .Cast<GraphicsStyle>()
            .ToList();
            GraphicsStyle invisibleLineStyle = null;
            foreach (GraphicsStyle g in _styles)
                if (g.Name == "<Invisible lines>")
                    invisibleLineStyle = g;
                    break;
