Inverse View Filter Rules
Hi All,
I am trying to make an addin (Revit 2018 with C#) that lists all the view filter in a project, with their name, their category(ies), filter rules and filter values.
As long as there are no inverse filter rules it works.
Please see this example:
if (rule is FilterDoubleRule)
FilterDoubleRule fdr = rule as FilterDoubleRule;
if (fdr.GetEvaluator().GetType().Equals(typeof(FilterNumericLess)))
comparator = "<";
else if (fdr.GetEvaluator().GetType().Equals(typeof(FilterNumericEquals)))
comparator = "=";
else if (fdr.GetEvaluator().GetType().Equals(typeof(FilterNumericLessOrEqual)))
comparator = "<=";
else if (fdr.GetEvaluator().GetType().Equals(typeof(FilterNumericGreater)))
comparator = ">";
else if (fdr.GetEvaluator().GetType().Equals(typeof(FilterNumericGreaterOrEqual)))
comparator = ">=";
ruleValue = fdr.RuleValue.ToString();
I do the same for the Integer and String rules. And this works.
But when there are inverse filter rules like "Not Equal", "Does Not Contain", "Does not Begin with", ... then I don't know how to access the filter rule and rule value.
I hope that somebody here can help me.
Thank you in advance.
CADsoftOrl
Negated filters are wrapped in a FilterInverseRule object, so you'll need to check if your FilterRule is a FilterInverseRule, and if so, call FilterInverseRule.GetInnerRule().
if (rule is FilterInverseRule inverseRule)
    FilterRule innerRule = inverseRule.GetInnerRule();
    if (innerRule is FilterDoubleRule fdr)
Thank you for your answer.
I still have a question.
Let's say the innerRule is filterStringRule, that means the rule could be: "is not equal", Does not begin with", Does not end with" and "does not contain".
How can I figure out which one of these rules is used in the filter?
Thank you.
CADsoftOrl
You would want to look at the type returned by FilterStringRule.GetEvaluator().
if (rule is FilterStringRule fsr)
    FilterStringRuleEvaluator evaluator = fsr.GetEvaluator();
    if (evaluator is FilterStringBeginsWith)
        // If the outer-most rule was a FilterInverseRule,
        // and FilterInverseRule.GetInnerRule() returned a FilterStringRule
        // with a FilterStringBeginsWith evaluator,
        // then this is a "Does not begin with" rule
    else if (evaluator is FilterStringContains)
Great. That works.
Thank you very much.
